Hello All
Took my new-2-me Balboa 26 out for her first shakedown cruise Sunday. As expected, a lot of things went wrong but most of those I know how to handle.
I had a lot of trouble with my 15 hp 4-stroke Honda outboard. It had been recently serviced by someone I trust and was reported to be "running great". But yesterday I could not keep it running unless I left the choke at half. And then it would stall anytime I tried to run it at low rpm. Since approaches to the dock under full throttle are frowned upon, I need to fix this.
So here are some additional variables. The guy at the shop had used his own fuel tank. I had emptied and replaced the fuel in my (internal) fuel tank prior to heading out. I also added a can of seafoam.
At this point, my best guess is that the in-line fuel filter might be clogged up with ick. Or maybe there was some sludge in the bottom of the tank that got up into the fuel injectors. But I'm not a mechanic and don't feel very knowledgeable on outboards so... If you have some suggestions, I'm all ears.
Thanks,
r
Thanks,
r
