If the anti-freeze is Dex-Cool, are there any indications of problems before damage is noticed --- such as the coolant turning black?
I ask because before the first outing after I bought my boat (1.5 years ago), I drained (but didn't flush) the coolant, then added new anti-freeze (lime-green Prestone). After returning to the dock after my first day, I noticed that the coolant was jet black. I drained again. In the container, the black precipated to the bottom after a couple of hours leaving the upper section of the liquid pristine looking lime-green. After refilling with clean anti-freeze, the coolant turned black again almost immediately.
At the time, I posted the question on this site and got some good responses. Several suggested blow-by of exhaust past the head gasket into the coolant. Another said it could be the type of coolant (GM). Other than the black, the engine was performing wonderfully, and because a blown head gasket is something I wanted to wish away, I first focused on the coolant.
Anyway, it took quite a few flushes over several days of motoring to finally clear out all of the blackness. I've replaced with an extended life coolant. Now I've gone 11-12 months and the coolant is still lime-green (yes it's time to drain and replace again). The engine still works just fine, so seems that the head gasket is OK. Hope if was Dex-Cool, I got rid of it before any deep damage.
MaineSail, thanks for starting the thread on heat exchangers. When I bought my boat, the heat exchanger had some pin-hole leaks. A local radiator shop fixed it up almost like new (albeit for more $'s than you paid -- but I live in a San Francisco area county where repair shops price for owners of BMW's, Mercedes, Porsches, Lexus's, Jaguars etc which seem to outnumber Fords/Chevy's by a good margin). I'm replacing the heat exchanger's seawater side zinc frequently. I am surprised at how fast it is depletes.
