Determining engine age
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
Hello folks,
Anyone know if, or how, you can tell the manufacture date of a Universal M-25 XP from the engine serial number?
Thanks,
Chris
From the ericson owners association website: In 1986 the M-25 was replaced by the Model M-25XP, a 57 cu in, 23 hp, 3 cylinder, based on the Kubota D-950 block and fitted with a Hurth HBW-50 marine transmission. It was built from 1986 to 1999. Approximately 3,100 were sold.
How many engine hours do you have? Is there any indication your C30 was repowered?
Nov 14, 2013
238
It's a 1983 C30 and the engine only has 800 hours. The boat is new to us, just closed this weekend. I was mainly wondering if the age could be determined from the serial number because one of the questions when applying for insurance was "what year was the engine produced".
Figure the engine was produced the same year or one year earlier. Nice deal with low engine hours. Have fun with your new boat. Congratulations and welcome.
If I haven't told you about these two good sources of information, have at it. If I have, well, then...:)
Critical Upgrades http://c34.org/bbs/index.php/topic,5078.0.html
Tech wiki, go down to engines: http://www.c34.org/wiki/index.php?title=Main_Page
Our boat systems are essentially identical, so you don't have to reinvent the wheel.
Apr 27, 2010
969
Beneteau 352 Hull #276 Ontario
Don't know if this helps any.
Attached is the manual and on page 2 ,lower left column, it indicates how to read the serial number for dates of manufacture.
Good luck
238
Good luck
Thanks joker and stu, great info.
the serial number I found, or at least I thought it was the serial number, is all numbers, no alpha. I'll take another look tomorrow.
