I was experiencing some overheating when running my Universal M-18 with a noticeable lack of sufficient exhaust flow recently. I did not allow the engine to overheat (280 degrees too long).
When removing the cover off my Sherwood Water pump I noticed that the impeller was severely deteriorated (crumbled bits of rubber and 1/3 of the rubber flanges gone).
The engine is logging 500 hours and I do not believe the impeller was ever changed by the prior owner. Now that Lake Lanier is still low, I seldom venture from the dock these days, so I figured age and dry rot has taken its toll. I did remove the hose from the pump to the heat exchanger and removed the "T" fitting on the pump that caught a few of the rubber chunks. Where else can the rubber get lodged? Fresh water is pumped through the impeller directly to the heat exchanger and out through the exhaust port.
Here is my question:
I am concerned that I might have some rubber in the heat exchanger tubes that would restrict flow. Having never taken off the heat changer can someone provide some good tips for inspection and cleaning? Obviously I release the coolant when removing the heat exchanger. Would I have to use compressed air? Would be it wise to replace the exchanger with a larger unit at this time? The boat has always operated in fresh water.
Any pointers would be appreciated.
Thanks
Bob
Catalina 30
Universal M-18
Thanks
Bob
Catalina 30
Universal M-18
