Designed
Jun 4, 2020
45
Beneteau Oceanis 281 Cheney Reservoir
Not being a boat designer, I wonder about fresh water tanks and whether they are supposed to be full of water all the time in order for the boat to sail to its spec's. Having 150-300 lbs. of water at the bottom of the boat near the center of gravity would seem help with stability. If one keeps it empty, does it impact the performance of the boat?
The installation of water tanks in a 26ft boat is convenience. Location is design. If you have to carry fresh water on board than carry it low and centered. If your racing than strip all the convenience items off the boat that the race rules allow. Light is faster.
Seeing that you are on the Cheney Reservoir, I can better understand the forced winter hiatus from sailing.
The Puget Sound allows us to sail year round, if your ready to brave the winter.
Yes, it affects performance. Exactly how and whether that is positive or negative can vary. As JS said,
Light is faster.
But...
Some boats steer better with a little more forward trim, others get very tender with empty fuel or water tanks. The designer will consider the intended purpose of the vessel and attempt to optimize for that. A racer is going to be light, light light light. A bluewater cruiser will be equipped to cross oceans and weather storms and house people who live aboard. A weekender has its own criteria.
The hull shapes, the location and amount of ballast the size of the rig all balance to give what the designer believes is the best solution. My Marine 19 is said to perform better with a little weight added forward. Those who have put batteries between the v-berths swear they sail better. A larger boat may not notice the difference of 150 lbs of water or even 300 lbs. If you're under 40 feet, it's worth thinking carefully how you load your gear for a race or an ocean voyage.
Xstream, it would be a fun and informative exercise to pay attention and sail under both full and empty tanks. Does she get more tender, does she get more weather or lee helm, does she track and/or tack and respond differently to jib or genny or shoot, how does she get when the sea state picks up? Take her out and note these things down in your log.
-Will
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The water tank in my 323 is in the bow. I have had water in it once in the 16 years I’ve owned the boat. It seemed like it made the boat unusually nose heavy. In my opinion the boat sails better with less bow weight. Granted, I use it as a day sailer anyway.
Consider the weight of the water in a full tank, then add the weight of the anchor, chain, and rode and that’s like having a person in the v berth 100% of the time.
