aft-fwd transducer does it make a difference?
Lets see, say you are going 2kts, at 6020 ft in a nautal mile, that's 12,040 ft in one hour......or 200.7 ft in a min. .........3.34 ft in a sec.....figure 15 feet between fwd placement and aft placement that gives you an extra 4.5 seconds to react, take me that long to get up off my seat, that's at 2kts,,,, I guess that if the bottom was rising that fast it would be worth it, but under NORMAL conditions (if they exist) wouldn't you know the bottom was comming up?... now lets speak of the accuracy of the depth meter???? due to temature and salt content My boat has a swing keel and rudder a Hunter 260, I think I will put my transducer aft of the sump pump under the aft berth as recommender by Hunter (I called) a retired Navy Sub sailor
