My SR Mariner depth sounder gives depth readings while under motor power. However, when I cut power and go to sail the readings become erratic. Any Ideas about what is going on? ThanksJohn
I would say you are probably not getting full voltage when the engine is not running...either because of corrosion on some terminal connecting the sounder, or weak battery(s). When the engine is running(and producing higher (13.8volts)voltage) it probably is enough to properly power the instrument.
