Tom
I've read with interest the discussion on replacing the depth sounder. Can any of you who have replaced the existing unit ('84 Cat 30 - I think it's a Standard Horizon) with an inexpensive fishfinder tell me the model you bought? Can you replace the in-hull transducer without too much difficulty or did you mount a speedboat type transom transducer? Where have you mounted the fishfinder display unit - obviously it wouldn't fit in the existing 'dial' hole. I am thinking of a swing out bracket as I don't want to cut a hole in the fiberglass.Thanks for all your advice.
