depth sounder replacement
shank
Apr 20, 2016
125
Catalina 27 5231 Lake Champlain
The 87 model I recently purchased has an old Kenyon depth gage mounted on the wall next to the companionway in the cockpit (sorry, I don't know what this is called). It no longer works and the wiring on the inside has been cut away. Can anyone offer any good suggestions for a replacement? I would kind of like to find something that fits the same hole as the Kenyon rather than looking at a broken gage all of the time. Thanks
shank
Apr 20, 2016
125
I'll have to measure it when I get home. I thought maybe the hole was a standard size on this boat
Nov 19, 2008
2,129
Catalina C-22 MK-II Parrish, FL
Looks like a standard 2" depth sounder hole, but measure it, easy swap if it is.
Sep 14, 2014
1,272
Catalina 22 Pensacola, Florida
If its a 2 and 1/8 hole the in dash humminbird will fit just nicely. About 109 bucks comes with a transducer you can stick inside the boat up forward in the hull with toilet wax and even has three different colors of trim rings. see pix
