Depth Sounder Problems
ChuckH
Hunter 33.5 Laconia NH
My Datamarine depth sounder is reading a constant 16.6 feet. It doesn't vary from that reading even when traveling over different depths. The transducer doesn't appear to be fowled. I tried cleaning the cable connectors with no luck. Any suggestions?
Jun 6, 2006
6,990
clearly you have a gremlin swimming below the transducer :)
I assume you tried powering the unit on and off. (the microsoft solution!)
Did it just start doing this or is this a new install?
