Depth sounder and speed stoped working
Feb 19, 2020
16
Beneteau Oceanis 38 Newport R I
Hi, I have a 2016 Beneteau Oceanis 38, the Depth and speed have stoped working on my MFD. I have a B AND G Zeus2 system. Does anyone have any suggestions other than a new transducer?Does anyone know where the fuse might be located? Anything I can try?
Thanks in advance for any suggestions.
Ron
Nov 21, 2007
673
Check the network settings and find the sources for you data on your Zeus MFD, see if your transducer shows up as the source for depth and speed. You can try to auto-select the data sources to see if the missing data comes back. I have had to replace the transducer (but using auto-select resolved problems several times over a couple of years before the replacement). There is a similar current thread here; Help with B&G systems
