depth gauge
  • Thread starter Richard McCormack
  • Start date
Rich / O272
transducer location?
I assume that your depth instrument is located in the bulkhead, so you probably want to know the transducer location. Mine is a thru-hull version and located just ahead of the keel. Gotta pull the boat in order to service/replace the thing. Hope this helps.
V
Vic "Seven"
On Seven the original transducer was under the ...
vee berth just to port of the holding tank. I left it in place after it stopped working and added a fish finder about the same place epoxied to the inside hull on the starboard side. No problem as the hull, about 8 in. from the center line, is thin enough not to bother the signals. Probably cheaper just to get a new one than try to pull boat and try to fix old one. Vic
