Depth Gauge Leak
There are two kinds of leaks. The transducer can leak around the thru hull fitting, which can be sealed with 5200 sealant. The other leak is the "o" ring itself which seats the transducer into the transducer well.Here is what I would do:1. If definitely around the thru hull fitting: Buy a small tube of 5200 sealant and apply to the area around the transducer thru hull fitting. Do not get it on the transducer itself. The 5200 needs to cure and can take several days, depending on temperature. The water pressure might push the 5200 away from the leaking area and it will appear to "swell". Press it into the area leaking and allow to cure to see if that works. It is better to do this out of the water and allow the 5200 to cure and seep into the leaking area, if you can.2. If leaking from the transducer well. You will need to replace the "o" ring.Unless you are experienced and have done it before, have the boat pulled out of the water or get a qualified service person to do it in the water. You should have a blank plug to put in the transducer well, while you replace the "o" ring. It is much easier to do this out of the water, of course.
