rad
Which do you prefer and why. Do you use a positive offset on your depth gauge, which will give you the actual water depth?Do you use the negative offset, which reads from the bottom of your keel to the water bottom?I just installed a new Navman 3100 depth gauge and my buddies and I were discussing the pros and cons. I figured I would ask you guys!
