depth finder
24
ODAY 27 Wrens,Ga.
Left my depth finder on over night. When I came back it was pegged at one fifty. What can I do to fix it?
Hunter 34 Alameda CA
Sort of like when I would call the IT guys at work. They always asked "Did you turn it off and back on?"
Do you have a manual or find one on line? It may have programmed a keel offset itself or it needs a reset. Hard to tell without documentation.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Hard to see why leaving it on should bother it. I would check to see if you have low voltage from running down the battery. Electronics do funny things when they don't get enough juice. I had some electric company guys screw up the wires coming into my house once, everything read 120V but nothing would run, they had clamped a wire partly over insulation on the wire to the street. It had voltage but couldn't carry any amperage. Blew my furnace relay, and refrigerator. I've had a depth sounder on continuously for several day without problem so that alone shouldn't hurt it.
Aug 14, 2013
24
ODAY 27 Wrens,Ga.
Checked battery, had a little over 12 volts. Will disconnect for a while. Thanks for the reply.
Aug 14, 2013
24
ODAY 27 Wrens,Ga.
A little over 12 volts is a fairly low state of charge. What's the voltage at the depth finder?
Didn't check it there but will. Also, I put two new batteries in but they both failed to register normal on the panel. Will recharge both and then see what they read.
Where is a good place to buy a used maintain?
Aug 14, 2013
24
ODAY 27 Wrens,Ga.
That's mainsail
Wdmcp
Jul 15, 2012
16
Most likely won't work for you. Sail would to large and need reworking.
Look on eBay might find something there.
