Try It First
Ours is a Garmin GPS/Sounder so we get everything in one package and on a single display. We mounted the sender 'puck' inside the hull at Garmin's suggestion. You can try various locations on the hull by using KY Jelly to fill the voids, just like the clinic makes ultrasounds of our bodies. When you find a 'sweet spot' just clean up with soap and water, let dry, then mount permanently with RTV or Epoxy. I used a silicone adhesive so it can be removed with a razor blade but the important thing is NO BUBBLES.The deepest water I've sailed in is 75' and it works fine and even spotsfish and tells you the character of the bottom.KenS/V Wouff Hong
