Alcohol stoves
Bob,You've been warned about the dangers of alcohol fuel, but from a practical standpoint, we use alcohol on board for cooking (Origlo non-pressure stove) and I occasionally heat the cabin with the cook stove. My thought is that there is normally sufficient ventilation on a sailboat with a sliding hatch and companionway boards which do not fit snugly to reduce (not prevent, mind you!!!) the risk of CO poisoning. If there is any doubt as to sufficient ventilation when using alcohol, crack the companionway boards or crack the hatch cover a bit. It sounds self-defeating to let the heat out that way, but better safe than sorry.
