Delamination tips
Joe McGinnis
I have a '77 O'Day center cockpit. The previous owner installed two Beckwith vents through the deck fore of the coach and back of the anchor locker. The wood has finally delaminated. The area affected is about 3' x 4' and does not extend to the edge of the deck at the deck/hull joint. Anyone else run into this? Is this a job for the do-it-yourselfer, or is it best left to the pros?
Justin - O'day Owners' Web
Delamintation
This is a job you can do if you want to try it. Try www.westsystem.com for information on the job. You will need to take your time but its doable. Cut out the outside skin. Cut out the bad wood. Lay in adhesive mixture. Fair it. Replace the skin. Fair it. Paint it. Sounds simple, is simple. It will be time consuming, though. Check that website, then check back with us. Good luck. Justin - O'day Owners' Web
Joe McGinnis
Thanks Justin
Justin, Thanks for the tip. Dug out my West Systems book, and have the info. However my wife thinks I should hire someone to do it. Just because she can't get the fiberglass off the kitchen cabinets from my last project. . .
F
Frank Bihon
Front deck delamination
I have a 32 with the same problem...I cut out the inner liner with one of those roto cutters and a carbide bit....stripped out the rotted wood and epoxied in plywood and re[placed the liner and epoxied in in real well...held the liner up with sticks until it cured....then installed two clear deck plates that let in light anc can be removed for air.....covered the cut with carpet and it look great....you can do it, just messy
Thad
Foredeck delam fixes
This year I replaced the core in my foredeck, and cabintop. It was time consuming. I replaced the core on the cabin top with 1/4 inch white cedar, and the core on the fore deck with 1/4 luane underlayment plywood. It seems to work pretty well. Oh yeah, I covered the seams of the top deck lamination with 2 inch glass tape. it wasn't too bad.
