I have just bought a used Oceanis 400 with a 19" Classic three blade prop on it. The boat has a Perkins 50 hp with a 2:1 ration on the gearbox. I am experiencingsignificant problems with the engine that I am beginning to suspect are related to the pitch being set too high. I have a feeling that the desiel is labouring too hard and is smoking as a result of strain over an extended period of time. When moving forward I get about 6 knots boat speed at 1900rpm Pushing it any harder seems to really bring on much smoke and vibration. The tack goes to 6000 so I assume the engine should at least reach 3500 with ease. The best I can get is 2500 from her with about 7kts at that rpm. I have not touched the prop but assume that the yard that installed it did set it at 20 degrees. Can you comment on the correct setting and size of prop? Can you also advise on your experience on engine damage if the pitch is set too high?Lastly I am confused about fresh water sailing with zinc annodes vs magnesium which I have been advised are much more effective for a saltless sailing environment.
