C
Cliff Carter
I received an unpleasant surprise today when I went to start our 1977 C30 with a YSE12 Yanmar engine, no compression at all. I had run the engine three days before for approximately an hour with no problems. I shut the engine off after docking and it was fine.I checked the following to ascertain the problem but so far no luck.1. Checked decompression lever - Neg.2. Engine cranks over too fast and easy. Crankshaft and rod still attached.3. Fuel to the engine. OK.4. Removed valve cover and valve train operating to the eye as it should.5. Checked dip stick and no water in oil.6. Suction on the intake pipe on the down stroke. OK7. Some back pressure can be felt through the top of of the oil filler tube on the down stroke.My next task will be to remove the head and hope I have a bad (very bad) valve. This will also let me view the piston top.Is there something that I am missing that is simple and causing this problem?The engine is a single cylinder 12 horsepower unit which has a little less than 800 hours on a rebuild by previous owner.Any suggestions would be appreciated. ThankxCliff CarterPlusOneC30 #598
