Winterizing
Hi Bill. Never been to MO, but I think the basics are the same. Pull the outboard and winterize as per manufacturer's instructions. They may be saying run with fresh gas and fuel stabilizer til out of fuel (just enough to keep fuel stabilizer in your carb(s, not gallons!), pull plug(s) and squirt some motor oil into the cylinder, turn over a few times to distribute oil around cylinder(s), replace the plug(s). Grease everything that already has grease on it and take this opportunity to check for rusted bolts, nuts, connections. Place on stand or on side as recommended. Replace filter in fuel line, dump old gas. Charge/clean your battery and remove to cool dry area. Remove all removeable electronics to warm, dry area. Clean their contacts. Clean the portapottie. Bring home the stove, clean connections. Check all halyards and sheets for wear (especially where the halyard will turn and not be seen!) Go home, wash up and start thinking about the trailer. Have a drink. Good luck.
