Hi everyone
I am planning to install a deckwash pump on a 2007 B40. Based on various websites I have scanned, I am thinking of putting in a new thru hull under the V berth, and connect the pump to the bow thruster battery that is also located there. I was anticipating of running the hose from the pump through the anchor bulkhead, using fittings at the bulkhead, and then up to the deck in the anchor locker. I did not want to try and run a hose or pipe through the forward cabin.
I have no thru hulls already in the forward cabin to T the water supply into (only one mid cabin head on this model). Suggestions?
