I bought a Beckson-Vent-O-Mate model C-6 for $22.00 in 1996 from "Cuban Joes" in Key West. Works great, opens and closes from below. you can find pictures at the following web site: Vent-o-Mate Ventilators by Beckson Vent-o-Mate Ventilators by Beckson Beckson\'s Plastic Vent-o-Mate Ventilators
C-6 Exhaust Vent
BETTER VENTILATION
24 HOURS - DAY AFTER DAY
NON-STOP - YEAR AFTER YEAR
Powered by just a slight breeze, the Vent-O-Mate® ventilator automatically
exhausts stale, hot and moisture-laden damp air from inside a closed boat to
help eliminate mildew and keep odors from accumulating - No need to wonder
why your solar powered vent is not working. Wind moving over the open grill
on top creates a partial vacuum that literally sucks air out of the boat -
removes 350 cu. ft. of air per hour with a breeze of only 6 mph. That\'s
enough to completely change the air in a 30\' sailboat in about an hour.
Vent-O-Mate® is also ideal for adding ventilation to heads, galleys,
forepeaks to help prevent mildew damage to interior wood and cabinet work.
Install over anchor locker to dry wet line and keep musty odors from below. A
clear shield on top permits light to enter and the vent can be closed from
the inside during chilly weather to retain cabin heat.
- Draft free - Water tight - Allows light below -No obstruction below deck
Unsurpassed Exhaust Ventilator, No more dampness, mildew or condensation.
Model No. - C-6SS - Vent-O-Mate® Ventilator with
stainless steel cover. We suggest C-6SS in heavy traffic areas.
Model No. - C-6 White C-6B Black - Vent-O-Mate® with plastic
cover.
Dimensions: Over All -
7 3/4" (19.7cm) Dia. x 2 1/4 (5.7cm) Hole Cut - 4" (10.2cm) Dia.
Covers Only -
C-6R White C-6RB Black C-6RS Stainless Available Here
Installation Instructions
MSG Frank Gallardo Jr. Casualty Assistance Volunteer Berlin Military Retiree Council U.S. Army Special Forces Retired From: "johnsons185@... [AlbinVega]" <
AlbinVega@yahoogroups.com> To:
AlbinVega@yahoogroups.com Sent: Friday, June 17, 2016 3:32 PM Subject: [AlbinVega] Deck vent
Hi,I need to replace my deck vent above the heads, I have found a 9" S/S ventair unit which does not open and close like the original one. I cant seem to find one similar to the original, has anyone else replaced this and what did you use?regardsScott JVega 891 "Mistral"
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 --
#ygrps-yiv-1546577756yiv0866030332ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp #ygrps-yiv-1546577756yiv0866030332hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp #ygrps-yiv-1546577756yiv0866030332ads {
margin-bottom:10px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp .ygrps-yiv-1546577756yiv0866030332ad {
padding:0 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp .ygrps-yiv-1546577756yiv0866030332ad p {
margin:0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mkp .ygrps-yiv-1546577756yiv0866030332ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ygrp-lc #ygrps-yiv-1546577756yiv0866030332hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ygrp-lc .ygrps-yiv-1546577756yiv0866030332ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity span {
font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity span span {
color:#ff7900;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332activity span .ygrps-yiv-1546577756yiv0866030332underline {
text-decoration:underline;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332attach div a {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332attach label a {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332bold a {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 dd.ygrps-yiv-1546577756yiv0866030332last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 dd.ygrps-yiv-1546577756yiv0866030332last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 dd.ygrps-yiv-1546577756yiv0866030332last p span.ygrps-yiv-1546577756yiv0866030332yshortcuts {
margin-right:0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332attach-table div div a {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332attach-table {
width:400px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332file-title a, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332file-title a:active, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332file-title a:hover, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332file-title a:visited {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332photo-title a, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332photo-title a:active, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332photo-title a:hover, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div.ygrps-yiv-1546577756yiv0866030332photo-title a:visited {
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 div#ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg #ygrps-yiv-1546577756yiv0866030332ygrp-msg p a span.ygrps-yiv-1546577756yiv0866030332yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332green {
color:#628c2a;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 o {
font-size:0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332photos div {
float:left;width:72px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332reco-category {
font-size:77%;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332reco-desc {
font-size:77%;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 .ygrps-yiv-1546577756yiv0866030332replbq {
margin:4px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg select, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 input, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg pre, #ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 code {
font:115% monospace;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-mlmsg #ygrps-yiv-1546577756yiv0866030332logo {
padding-bottom:10px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-msg p#ygrps-yiv-1546577756yiv0866030332attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-reco #ygrps-yiv-1546577756yiv0866030332reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-sponsor #ygrps-yiv-1546577756yiv0866030332ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1546577756 #ygrps-yiv-1546577756yiv0866030332 #ygrps-yiv-1546577756yiv0866030332ygrp-vital ul li:last-child {
border-right:none !important;}
