steve rainey
I have a 78 Hunter 30. Corrected the typical mast sag problem by cutting from the top deck down to the cabin liner and filled the whole area in with heavy glass mat. The pressure post was reseated and shimmed so its in there tight. Whats the purpose of the plywood I took out that was inbedded in the deck under the mast step? Is this fix going to hold up and not crack? The glass plate under the mast step is about 2" thick. The step sets on a raised T shapped area. The whole raised area was drilled out and filled in.
