Deck Skylight
A
Andy
I have a skylight over the forward berth that is cracked and I would like to replace. Rather than cut a piece of plexiglass I would rather have and OEM part but have been unable to locate one. Do you have a source for this item. It is a 1986 Cat 22. Thanks
Jun 3, 2004
730
Catalina 250 Wing Keel Eugene, OR
Local plastics shop
If CD doesn't have it then try a local plastic shop. I have that same "skylight" (bad design in my opinion) and I replaced it with a tinted Lexan one that matches the C22 windows. It looks great and is held with Silicon. I removed the lower skylight (Mine had two in a sandwhich sort of setup) and did not replace it. A local shop cut it out to size.
A
Andy
Thanks. The Lexan soundslike the winner. CD did not have nor had any sources. Thanks "y'all"
