Deck sealer for radio antenna wire
265
Macgregor 22' Long Beach
I am installing a mast-top antenna for my new marine radio and need to run the antenna wire through the deck. What is the best sealer to seal the hole?
Ross
Jun 15, 2004
14,693
The very best would be a piece of tubing
bent like a candy cane and glassed into the deck. The coax would then be led through that conduit with a drip loop on the outside and a threaded compression seal on the outside end of the conduit.
L
Liam
Do it right
I can't believe this... Hey Ross, Why not just pound a coke bottle through the deck, glass it in and then build a dorade box around it? Novelman, just go to a marine hardware store and buy a waterproof deck gland. They make them specifically for this and they cost all of $15. Or you could do it with a bunch of crap from the junk yard. That would really enhanse the value of your boat.
Benny
Yes, install a connector. It is the proper
and least expensive way in the long run. Besides having to reseal often you may get humidity and rot on the deck wood.
Ross
Jun 15, 2004
14,693
Liam he asked for the best not the most practical.
Have you ever tried to pound a coke bottle through a deck? You have to drill a pilot hole first. The big problem is they are only open on one end. That makes it hard to feed the wire through. ;D
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
There is a special coaxial deck mount seal.
It has a seal and a screw on cap.
Ross
Jun 15, 2004
14,693
The problem that I have with coax feed thru
connectors is the multiple breaks in the cable. Each one has the potential for trouble. I really wasn't being a smart a** when I sugested what I did earlier. Several thousand U.S. Taxpayer dollars provided me with an education in ground radio repair will I was in the Air Force. 99 percent of the transmitting trouble can be laid to the coax connectors. Silicone grease will indeed keep the water out. Salt air can effectively short out the antennas. On the coast of the Philipines we had to clean all of the insulators on all of the antennas each month and coat them with silicone grease. If the coax runs down the outside of the mast all of the water that hits the cable will drain onto the connector hence the drip loop.
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
I agree but...
he has to separate his cable somewhere, and gold plated terminals and silicon will go a long ways. Tim
Jan 27, 2007
383
Irwin 37' center cockpit cleveland ohio
guys, it's a 22' boat
Drill a hole. Inset wire. Caulk. Done. His boat is a 22' Venture. It's not the Queen Mary. Simple and easy does it.
jimq26
Jun 5, 2004
860
Oh - we thought he may want to drop his mast,.
You know, like maybe when he takes down the stick for trailering? Do they make stretchy coax?
Dec 25, 2000
5,919
Do you already have a wire chase ...
inside the mast and through the mast step plate? Most sail boats do for the various mast lights; anchor, running, etc. If so use the existing chase rather than cutting a new one somewhere outside the mast. I always get good performance using 3M4200 sealant on our boat. Home Depot carries it. I never use Silicone II on our boat. Terry
