Deck organizers
Brian
Passage 42 owners.....have any of you replaced the garhauer organizers under the deck cover with a different brand? I was thinking of switching to the harken triple and double stack them for more lines. I believe there is enough room under the cover but I will have to increase the opening hieght. What do you think? Thanks for the input in advance....
Dec 10, 2003
160
Hunter 30_88-94 Edmonds, WA
Garhauer will built it....
Garhauer will build stacks for you. Better quality, lower price.
Dec 25, 2000
6,071
Brian, why do you need more lines into...
the cockpit? I've set ours up so that the eight is enough even with a spin. If you are adding a staysail, boom brake, etc., then maybe the extra lines are needed. Terry
Paul Cossman
how do you remove the old ones?
Brian, I have had some spring problems with my old line brakes, but haven't figured out how to get them off for a change out. It seems that the things are bolted in place with the nuts hidden between the galley/cabin headliner and the cockpit area where they are bolted. Do you have to cut an inspection hole to access the nuts?
