The method I used , worked well on 6 other boats .
The method is simple, I first masked a 2" wide strip down the centerline from anchorwell to cabin, I then devided my side decks into three sections, from the cabin area, I went port and strbrd, with a 2" strip, I radiused all the corners 2"R, I painted one section at a time anchorwell lid, port & strbrd forepeaks, and 3 side deck sections per side I laid down a heavy coat of paint, then with a plactic jar with it's cover drilled like a salt shaker, I sprinkled down 30to 65 grit clean sand until I could not see any wet sand remainding, after 2 hours, I brushed off the excess sand and vacumed it, then went over with a second coat of paint ontop of the attached sand, and it looked and felt great, then I moved to the next section and so on until decks, cabintop and cockpit were done, my total cost was $31.00, 5 qts paint, masking tape, paint brushes, and a pint of white gloss enamal where the 2" wide strips were, these became my rain and sea water runoff chanels, The paint I used was bought at home depot, American best outdoor porch paint, blended to my desired color, I've tried the best marine paints, and the gloss doesn't last 6 months, this cheap stuf, has lasted longer and still looks great, and the 6 other boats that followed this plan, are all doing great under florida hot weather, P.S. Yes you do have to prepair the surfaces, prior to paint, but with this method, repair patches, if any are not visable, and if the texture is a little too rough for your feet add a 2nd top coat.
