deck light / spreader light
Torsten
Hi all , we just bought a 1985 Catalina 30 and we learn as we go along. Survey showed most things working but a few need to be repaired. An easy one is the missing bulbs in the decklight which is (if I am not mistaken) on the underside of the spreaders close to the mast. Well , before sending up the wife can anyone tell me what the standard issue is for these bulbs ? That way I can haul her up well equipped. Thanks, Torsten
Dean Bachelor
This may help
Hey Thorsten, I just ran out the boat garage & looked at mine, also an 85TR. The bulb has no numbers but it is a small flat type bulb with 2 tiny wires sticking out, like an old fashoned photo flash bulb. Mine is missing the protective lens so I will probably change out the unit this spring. S/V Ruba'iya't www.blowinganddrifting@yahoo.com
