Deck Layout - Template or Drawing
Jun 29, 2015
22
Hunter H260 Brighton Ontario
Anyone on the forum have a deck layout drawing with measurements? I'm looking to get a quote for fear teak upper decking. Basically looking to cover all of the diamond surface with nuteai/plasteak or equivilent. Just wondering if someone has a template, drawing, measurements so I can ballpark the coverage square footage (or better yet provide an actual template!).
The alternative is paper templating the entire surface just to get a ballpark quote.
Thanks in advance
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Simplest and lowest cost is to get a hold of your local SeaDek suppler, Launch Marine Products in Hagersville, Ontario . They will come to your boat, scan the areas you want covered, make computer aid design (CAD) drawing , fabricate each section and install it. Nice thing about SeaDek is it does not require sanding and gluing the material to the deck, is completely reversible and you will have a template to purchase replacement sections. I had it installed in my cockpit and stern.
Thanks in advance
When I need to make a template, I usually get some of that inexpensive plastic sheeting you buy in the paint section at Lowes... tape it in place and trace with a sharpie.
Feb 21, 2013
4,638
Below is the product of the SeaDek scan, which they will price out fabrication and installation (peel and stick) at a fraction of the cost of Plasteak. I elected to do the cockpit, a portion of the gunnels (to make it easier for the dog to climb in/out of the cockpit), aft lazarettes, swim platform and captains seat underside.
