My 1991 43' hunter legend has an outward deck to hull flange. under the toe rail there seems to be two issues,
1: small hairline cracks about 5 inches long sporadically through out the length of the boat in the curve of the underside lip
are these hairline cracks common and not an issue? or does the toe-rail need to be removed and this section sanded down and re-glassed?
2: On the over hung toe rail (the bottom) seems to have caulking or 5200 coming out.
Can i simply re-caulk it in place or must the entire toe rail and deck to hull bolts be removed and re caulked?
has anyone else had these problems and decided to resolve them?
thxs for your help
thxs for your help
