Deck core thickness
Feb 11, 2022
3
Capital Yachts, Kenner Newport30, Kittiwake Rochester Harbor, Lake Ontario
Hi Everyone,
Acquired a 1966 Kittiwake last year. Needs work. Can anyone tell me the core thickness in the deck? Specifically the fore deck.
Hi Jon.
Sounds like you are a boat fixer. Nice hobby.
The Kittiwake boats are reported to be built by Kenner Boat Company.
You do not mention the length of the boat. Kenner built a number of boats. In 66 the Kittiwake was a new boat for the company. It would be difficult too guess the core thickness as some boat builders used plywood, others Balsa, and some just laid up fibber glass. You are likely to find that the deck varies in thickness depending where you are on the boat.
I find that true on my boat. Some area are 1/4" core others have 1/2" plywood.
So that I do not have to drill a hole, I look for a thru bolt, extract it and then inspect the deck thickness both glass and core if there is any.
