Well we survived the winter form hell in Massachusetts.
Now that boating season is upon us, I plan to replace the Deck Plate caps for the water , waste and fuel. I have a Catalina 30 and Catalina Direct says that their caps might not fit my existing pipes. Has anyone replaced theirs? If so, any issues?
With the exception of the waste, the caps are black and use a two prong key to open. The new styles use the winch handles and are color coded. The waste is chrome. I had to replace that cap 3 years ago and the new one never screwed in properly.
Also, I need to replace the Ball valve under in the head. Cat Direct does have a 3/4 valve. Again, has anyone replaced theirs? Advice is always appreciated.
last, how can I trouble shoot the macerator pump. After pumping the tank, flushing with fresh water and repumping, I run the macerator for 1 minute. It didn't turn on. Is there a fuse behind the switch panel?
Thanks, BobCat
Thanks, BobCat
