I am starting this thread for a discussion of all things Deception Pass.
For background, I moved to Oak Harbor, WA in 2005 and had a job in Burlington so I drove across the bridge at least 10-times each week. I always gave myself enough time to stop on Pass Island and walk out onto the bridge with current table and notebook to record the conditions at different current speeds.
What I found by that research and the added experience of more than 100 trips through is that there is a definite safe lane for any current speed up to and above 6-kts outbound and 5-kts inbound. If there is a safe lane that infers that there is a dangerous lane and that is also very true. FYI, I have never attempted to go through the northern Canoe Pass so cannot offer any advice there.
The safe lane is the same both in and out.
- When approaching the bridge from either side, divide the pass into thirds. The safe lane is the northern 1/3 of the width.
- Place your boat no farther south than the northern third line and don't let anyone push you south of midspan.
- To stay in the northern 1/3, you will need to angle about 10º towards the Pass Island shore and it is almost impossible to actually hit it. This is because the water on the north half of the pass is flowing in a rolling column of water. It flows up the face of the Pass Island and then out/through the pass and back down at midspan. This means that the along with the current pushing you through the pass, it is also pushing you towards midspan.
- The reason that it is "safe" is because the water is in laminar flow on the north half of the pass. This means that the water is moving in a straight line which few eddies or lateral currents. This is because the face of Pass Island is a vertical cliff that makes a nearly straight line for its full legth.
- The danger zone is anywhere south of midspan, and I never go there, period.
- In the danger zone, the water has turbulent flow with a series of whirlpools that alternate between clockwise and counterclockwise. This makes any boat out there repeatedly turn sharply into the Whidbey shoreline. This is caused by rock outcrops that extend well out from the Whidbey shore and are just barely covered at a minus tide. Nothing good on the south half of the channel.
- I almost always go with the current. The only exception to that is to push against the last of an opposing current at idle until it slacks enough to let me in.
- I do not try to hit the slack because it can vary up to 45-minutes from predicted and if it is going to opposed, you will not get through.
- Once you clear the pass, do not fight the wheel in an attempt to keep the boat pointed "in the right direction".
- There are whirlpools which are easy to avoid and will not do you any harm in a boat of 25ft or more.
- There are upwells which cannot be avoided but do nothing more that rotate the boat as you slide on through them.
- These currents will cause the bow to swing back and forth but let your boat have her head and gently guide her back in the direction you want because they are all out beyond the pass and there is nothing to hit if you drift around.
- The worst thing to do in the whirlpools and upwells is the try to keep the boat pointed in one direction because it adds a great deal of useless stress to the steering gear and everyone on board as the boat is jerked around.
