Brad,I have a 1989 F235 that I replaced the decals on this spring. You can order the entire "package" of decals that come on the boat from Beneteau. It takes a while to get them as they come in from France. They may be slightly different than the ones that came on your boat - mine were - but they look a lot better nonetheless.Regarding removing the old ones, I used a heat gun & a scraper. You have to be really careful with the gun so you don't melt the gelcoat, but they will come off. Also be careful with the scraper as it's extremely easy to get into the fiberglass. I actually used the back of the scraper blade as it wasn't as sharp & was less likely to get into the glass.
