doing same on my Oday 23
Hi Jim,I'm doing the same on my Oday 23 as well. In addition to installing a Raytheon knotmeter. I'm mounting my "thru-the-hull" transducer in under my V-berth..just forward of the keel and to starboard of my knotmeter (which is on the port side) It'll be like 9" or so forward of the keel.At that area, the dead rise angle isn't that high and should be a good enough placed for sound readings.Testing out your tranducer by done by Gary's recommendations. My instructions also gave some other options, one of them was by applying some petroleum jelly to the bottom of the tranducer and putting it in place with a twisting motion, knocking out any airbubbles. When it comes time for complete install, ensure you don't have air bubbles in the epoxy.
