E
Ed Schenck
All that work to get an early splash. Couple of warm days with south breezes and I cannot leave the slip. No engine because no waterpump. The old Jabsco(2760-003) started leaking and I do not have the seals to rebuild it. I did this a few years ago but I think the bearings might be a problem. If the shaft is wobbling then how long can the seals last? This appears to be a very weak link on the old Yanmar(2QM20F). The pump is the pedestal type, two bolt holes just two inches apart. It seems like too much stress from the belt around the crank and alternator for such a small mounting. On the other hand it has performed flawlessly for the five years I have owned her. . . until now.Has anyone replaced this pump with a newer and better model? In the catalogs it looks like Johnson might have a replacement. The problem is bolting it down and still having the pulley(4") line up with the alternator and crank. I'll be calling Torresen later today, they provided the original rebuild kit.What about a backup? Has anyone installed an electric pump nearby that could be used in an emergency?
