Dead engine panel.
Dec 4, 2024
2
Asante 1120 Bear
Hi,
The starter on my yanmar 4jh2e went in smoke. I replaced it with a brand new one and thought this was the end of my problems.....
The engine control panel is dead. Turning the key does not result in the noisy buzzer, no light, nothing.
I noticed two relays:
124817-91850 and Kissling 29.313.11 300A.
I need to know how the engine control panel gets its + and - ?
It is the B2 type panel.
Thank you.
7,604
Alden 50 Sarasota, Florida
You replaced a symptom rather than find or fix the problem which caused it. Lesson learned…
not sure if someone has a link to an online engine instrument schematic but if not, I can scan and post the relevant pages of the service manual from which you can trace the wiring.
2
Asante 1120 Bear
Gents, I found the wire - large diameter with red insulation. The engine is running again!
Thank you all who responded!
Welcome Mark, to the forum... You may have set a record. Joined the forum today, fixed the problem today. WOW!
Likes: Indysailor
