Scott
I'm not exactly a novice when it comes to sail trim ... but I haven't been able to figure out exactly what the vang is supposed to do. My boat has a traveller mounted at seat level behind the companionway. I've heard it explained that the vang assists the traveller in establishing the angle of attack. Also, I've read that the vang also influences the sail shape (draft?) for the lower third of the mainsail.But I haven't been able to see that it influences anything. To me, it seems that it merely pulls down on the boom, which is rigidly fixed (elevation-wise) to the mast. The sheet is either tensioned or slack, with no degree of subtle difference. I suppose that to some extent it is working against the mainsheet, which increases twist as it is eased, but so what?So far, I have merely tensioned the vang and left it be while sailing during the day. Occasionally I will pull on the sheet to see if there is anything I can affect but it always just seems to simply pull against a fixed boom. I feel like if I try to REALLY pull on it, I will simply be attempting to bend the boom, and what sense does that make?I often use the outhaul to adjust for wind conditions and I know that the Cunningham acts like a downhaul to flatten the luff. I have a great deal of experience with windsurfing rigs and know how to use downhaul, batten tension, outhaul, harness line adjustments, etc to perfectly balance my rigs for any wind condition. Much of this experience I have been able to translate to my boat ... but the purpose of the vang still eludes me!Am I trying to see too much in its purpose? Does it require a different setting for each point of sail? I know there are some explanations out there to enlighten me!
