Cross Beam Repair
Not sure if your mast is deck stepped or keel stepped. You might choose to add more information in your post.If it is deck-stepped it is fairly easy (but messy) to prep the under cabin top and glass new foam into place. Use epoxy and try to replicate the glass lay-up structure or exceed the original specifications.If it is keel stepped, cut out the beam, scarf a new one into place and reglass. Messy? yes. Pain in the bilge? Yes. IS a short cut available? No.Good luck.Charles Barclays/v Dealer's Choice (Islander 40)
