Alright all you volt-heads out there, I need your advice. The owners manual for my Xantrex Turuecharge 20+ battery charger says to disconnect all DC electric devices and loads from the battery before running the equilization cycle. They suggest that the higher voltages during equilization may damage radios, motors, compressors, etc. In the past, I have disconnected everything at the battery, including my bilge pump for the 4 - 6 hrs. What a pain!! Is this overkill and could I just as easily throw the breakers for my radio, DC refrigeration, fresh water pump, etc, to isolate them? The bilge pump and my AM/FM radio are the only loads directly wired to the battery.
