Suggest you look at the newer....
.... "cruising laminates" these are made of an internal mylar film and a layer of woven dacron is "sandwiched" to both sides of the mylar. These are lighter weight and stronger than plain Dacron. Dacron will protect the mylar, plus such sails are able to be 'folded' many times without harm; but, if you primarily roller furl such sails a dacron-laminate is probably your best value. The problem with the high tech materials is that although they may be good, they simply dont hold their shape (they eventually 'creep' under load) as long as well made dacron. Such lofts who push such materials on cruisers ..... probably dont have your best economic interest at heart or are depending on you not really using such sails to their limits. For longevity, nothing beats top quality dacron fabric such as from such manufacturers as Bainbridge, Marblehead, etc. but you will pay a little extra for these 'quality' materials. There is a lot of cheap dacron 'crap' showing up in sails, especially those made 'offshore'. You usually get what you pay for. A little 'twist' that can offer a good compromise between long life and economics for a roller reefed genoa is a radial cut made from different weight materials: heavier material at the leech (as the heavier less shape control needed leech is only exposed when the sail is reefed/rolled; and, lighter weight material at the luff - easier to roll, makes for a tighter roll and is only exposed when the wind range is appropriate for that weight. Less weight aloft, tighter and better 'rolls' (overall shape) when 'reefed', etc. Unless you are planning on an open ocean passage, I'd recommend that you consider one of the newer 'cruising laminates' for your genoa, consider different weights of cloth for luff and leech and consider a radial configuration (for shape holding ability). Will cost a bit more, but will result in a sail that will last longer, hold shape longer, etc. etc. For offshore, consider triple stitching and easily replaceable UV protective foot/leech edge covers. Also consider adhesive strips (PECO, etc.) under the stitching for panel joining. If you have unlimited funds you might also consider the stitching thread to be changed from polyester to ultra-modern UV resistant "technora" PTFE. Also consider for polyester thread ... one weight higher (heavier) than the normal grade - thicker will last longer in UV. Cheap 'crap' is ultimately more expensive as you will replace it sooner.
