d.c. throughout boat has gone down?
K
kurt Nerlinger
Spent the day going over all possible solutions,engine runs fine ,both batteries are charged,all fuses are A ok .Pulled switch panel and that to was fine. Any suggestions plase post on this site.....thank you ! My Hunter is 1986 28.5 in excellent shape.
Dave C.
Connections
Check for corroded or broken connections beginning at battery posts and working back to breaker panel.
Pete
not all the dc is down
if your engine starts not all the dc(starter is 12 volt dc)what about bilge pumps? I would advise to chech the power supply to the dc panel,get a tester and start checking from the panel to the batteries. Good Luck!
Steve Cook
Breakers
When my '99 H310 was hit by lightning back in August, most everything did not work (AC/DC) at 1st. we all thought it was the wiring. Later we found out that the breakers and diodes were all burned up. As with your house, breakers don't last forever. check it out. sc s/v The Odyssey...
E
Eric Lorgus
What is it that doesn't work?
Kurt, You say your all DC is down, but then mention that the engine runs fine. What is it that isn't working? And when you say the batteries are charged, did you use a voltmeter to test them? What was the voltage (in tenths)?
K
kurt Nerlinger
D.C.down!
Thank you Eric,Steve,Pete,& Dave for your advice on solving my problems.Please note that my boat has not been hit by lighting and that all breakers,fuses ,battery terminals&voltages have been checked for proper voltage & contiunity. Any more sugesstions would be welcome !
Dec 2, 1999
15,184
Grounding?
Kurt: Just a guess is that you have a bad ground. I am assuming that you have an AC and DC panel. Try to isolate the ground on the DC side and just check for corrosion or a loose ground wire. The DC side is basically lights and instruments (including your radio). Hope that is taking you in the right direction!
