I posted a message about rebuilding the head here http://forums.sbo.sailboatowners.com/showthread.php?t=113005
What is the best way to cut the hose to length? For rigid pvc I have always just used my chop saw with fast, clean results, wasn't sure if there was a better way to cut the hose?
For the stupid head trick. I noticed on our new boat, that the sink in the head drains through the thru-hull intake for the head itself. I found if I shut the intake
seacock off, and run the fresh water into the sink, I can use that fresh water to flush the head, bypassing using sea water! Probably go through fresh water too fast to use it full time, but it was something I found out when I winterized the lines. If nothing else, it would be an easy way to flush the sanitation hoses
Now got to remove the head, rebuild it, buy another $300 rebuild gasket kit, re-engineer the system according to the previous thread.
But my main question is how to get a nice good clean cut on the new hose
Thanks
Paul
Thanks
Paul
