Cutting an outboard motor well
I read the article of James Baldwin on cutting amotor well for and outboard motor. All Cal 20's were designed with an inboard motorwell already. They came with the plate shaped liked the hull bottom that you sail with attached to the bottom of the hull with Bungee chords and removed when you put the motor in.It definitly solves the problem of the motor's wieght out over the transom which causes the boat to pitch more in swells and since the motor is inboard of the transom, it doesn't come out of the water when the boat gets rocked around. One problem that Baldwin solved was also addressed when the Cal20 was new, water coming into the cockpit when the motor is in. Although very little comes in when your moving forward, a lot comes in when you back up. There was a cavatation plate originally with the Cal20's but it only fit the old 60's Evinrude motors. The other problems I find are, the motor is very noisy inside the boat because of the closeness and acustics. When you want to sail you can't tilt the motor out of the water, you have to lift it out and put it back in the locker. This takes a strong back, I have a Tahatsu 5 hp and it is awkward lifting it and trying to stuff it back in the locker when the boat is rocking around with the swells. My Tahatsu manuel states not to lay an outboard down either flat right out of the water, or definitly not with the cylinder head below the propeller because the water will run down to the hot motor and do some damage. I have rigged a support in the locker so the motor rests at an angle, head higher than the prop. I've actually been thinking about mounting a bracket on my transom, so I can just tilt the engine up, leave the bottom plate on all the time and sail. However my Cal20 goes thru large swells with no wieght over the transom much better than a lot of bigger and heavier boats I've sailed that have the motor hanging out over the transom. so I've always been undecided about this.One thing I do know, it has made me a better sailor out of laziness, I always sail in and out of my slip and very seldom put the motor in unless it's and emergency.
