A few observations
First, I haven't done this job myself yet, 'though I will this winter or next spring. Mine is a 1984 C-36, and i don't know when it was last done. It needs it - you can hear the vibrations when under power.There is indeed a setscrew in mine, but I only found it after scraping the bottom paint off with the back edge of a steak knife. I will check the other side for one, too. The screw was completely rotted out - nothing left but red dust. I can see the brass of the cutlass bearing. I am pulling the engine this year, so I have access to one end of the shaft without dropping the rudder. I plan on removing the shaft after pulling the prop and thoroughly cleaning the shaft so it slides through the stuffing box. I will then bring it home and put it on the lathe to clean it up nicely, and spray it with clear coat, masking for hte zinc. I may send the prop for repitching (suggestions?).For the cutlass bearing, I will cut through the brass shell with a hacksaw, and collapse it to remove. I'll then make sure the strut bore is clean and smooth. I'll measure the bore carefully, as well as the new bearing, and make sure I have a proper press fit. I may then hone the bore a bit. Finally, with a little lube, I'll press the bearing in. I plan on making a fitted hardwood drift for tapping it in. I hope I don't have ot press it with a lot of force. That's the plan.
