Cutlass Bearing for H37C (and H-36?)
If yours is the same as the Hunter 37C, it is 1" ID x 1 1/4" OD x 4" long. The part number of mine was "BACK". I made a puller from some odds and sods of big washers, a 1" socket (happened to be slightly less the 1 1/4" OD), a length of threaded rod and a few nuts to suit - this made the job very easy. I re-configured the same tool to press the cutlass bearing back into the strut. Don't forget to put some "Never Seize" on the grub screws when you install the new bearing. Good luck!
