Cutlass Bearing
wbg
Jan 8, 2006
1
- - medina lake, texas
I need to get a cutlass bearing for my 1977 30 ft Irwin -- my boat is still in the water awaiting haul-out on Monday 1/9 '06, so don't know the size (i.e. outside dimension) and need a quick turnaround. Does anyone know the bearing size and where I can get one? My yard man tells me it will take over a week to get one through his supplier and I have a transporter set up to move the boat by Friday 1/13 ,06. Any quick reply would be appreciated. Thanks.
W
walaafe@yahoo.ca
If you can dive, take a plastic caliper
If you can dive , you could take a plastic caliper and mesure your shaft diameter and bearing housing. Good luck,
jc
citation 31 cutlass
I have a 84 citation with a 16 hp yanmar and the bearing measures 1.5 x 3.5 x 7/8 shaft dia. Measure shaft inside boat, May not need to dive or limit time in water if very cold.
N
Nick Heath
Shaft diameter Irwin 30
The shaft diameter on Ganymede (77 Irwin 30 Competition) is 1" but I cannnot vouch that this is original. Ganymede is on her third (at least) power unit.
