I had my new Yanmar 2YM15 installed this spring and finally had her in the water by the middle of June so the engine is still just breaking in (and probably will be for a long time). With just 10 hours so far, the engine usage is light!
At about 3000 rpm and above, I've noticed a rattle that sounds like it is coming from the area where the cutlass bearing is. The mechanic claims that he was very sure about alignment, but he thought the bearing was a little sloppy. He said not enough to make an issue since he didn't want to delay the splash date by that time. But he says he is surprised that I noticed the noise because he thinks alignment is very good and the bearing not too bad.
I never noticed any looseness in the past, but my top rpm with the old 1GM was just 2400 rpm, to some extent because of being over-prop'ed. Now, the same prop seems perfectly matched.
The engine also idles very smoothly in gear when at idle throttle, but as I ease it up to leave the slip, I often notice a brief shudder when just nudging the throttle slightly. I observed the engine when this happens (with Sue at the helm) and noticed a very brief vibration at the back end of the transmission ... enough that the PSS spits a little water at a certain rpm just above idle. That has puzzled me as well.
I know that they didn't use new set screws and they must have loosened them when dis-coupling the shaft, so ordering new screws and replacing them with a new PSS setting is on my to do list. I get a minor amount of water leakage from the shaft when running for a period of 15 minutes or more.
Any thoughts would be appreciated!
