You don't need the strut size. The cutlasses are standardized. Assuming that you do the work in a boatyard, they'll have what you need. Or order one from your favorite store.
All cutlass bearings are not created equal, use a Johnson Duramax for best results. Don't forget to align the shaft only after the hull has been in the water for a couple of weeks so the hull can settle into its normal shape.
